  • 2 Vote(s) - 4.5 Average
TrueTone Model D-2026 series B Manual
#66
Thank You. Sams PhotoFact might be here tomorrow. Finally started to get shipping info and it's at my local distribution center. I find the route of shipments interesting. A lot like when I fly with the airlines. Seems the package drove past me and the local distribution center and continued down the road for 3 1/2 more hours. It then sat there for three or four days then came back up the same road past me again to finally arrive at my local distribution center. Guess I'm lucky it didn't get lost in the high volume, and lucky that my own activity isn't tracked.
Take Care
Tim
TrueTone Model D-2026 series B Manual - by TTech - 10-04-2020, 12:34 PM
RE: TrueTone Model D-2026 series B Manual - by TTech - 12-21-2020, 09:51 AM
There are currently 9909 online users. [Complete List]
» 1 Member(s) | 9908 Guest(s)
