Perpetuum Ebner Rex Deluxe alignment
Yeah, me too, but the other day I looked up a Dual 1009 and I guess that Ebner was related. Anyway the discussion was on a similar spindle and the "small pieces of rubber" that provided some friction so that only one record drops.
That is it. Maybe yours also had some rubber parts that are missing.
Perpetuum Ebner Rex Deluxe alignment - by morzh - 12-21-2020, 04:30 PM
RE: Perpetuum Ebner Rex Deluxe alignment - by Phlogiston - 12-21-2020, 05:09 PM
There are currently 10755 online users. [Complete List]
» 2 Member(s) | 10753 Guest(s)
