Restoring a Philco 39-45
Hi and welcome,
Can't help you with the service aspect but can tell you a few of the
issues you maybe facing.
In 1939 thru 1942 Philco radios used
rubber coat wire. This was fine for the 1st 15 or 20yrs but after that
the rubber starts to fail. Some rewiring maybe necessary.
Electrolytic and foil/paper capacitors should be replaced for safe
operation and good performance. Not doing so can cause damage
to major components$$
The two end tubes don't require shields, some of the others don't
need them.
The 39-45 is fine sounding set when serviced properly. I have a
similar set from 1941 (41-300) it's one of my favorites.
GL on your quest for service.
Restoring a Philco 39-45 - by originjazz - 12-21-2020, 07:14 PM
RE: Restoring a Philco 39-45 - by Radioroslyn - 12-22-2020, 12:53 AM
RE: Restoring a Philco 39-45 - by Arran - 12-22-2020, 03:15 AM
RE: Restoring a Philco 39-45 - by originjazz - 12-22-2020, 11:49 AM
Philco 91 Tuning Condenser
There are currently 9289 online users. [Complete List]
» 2 Member(s) | 9287 Guest(s)
