DeForest Crosley console
I bought this radio from a fellow in Edmonton, and I have it recapped, and playing good.
 I had to rebuild the system that controls the dial. It is a system that uses  a wire wound around the tuning dial knob and the top portion with the actual dial.
   The indicator is three lights that rotate around as you change stations. Each band has its own light.
   I will get to the cabinet in the spring. It is not a high tube count, but I really like the cabinet and the dial.
   I have a pretty good idea of what it will look like after I am done.
These Rogers and DeForest  radios all have very nice dials.   It Is a model  7D932
 Dan in Calgary
   Living in Calgary Alberta
DeForest Crosley console - by Dan Walker - 12-22-2020, 10:39 AM
RE: DeForest Crosley console - by Arran - 12-24-2020, 01:58 AM
RE: DeForest Crosley console - by Dan Walker - 12-24-2020, 10:35 AM
RE: DeForest Crosley console - by Arran - 12-29-2020, 04:11 AM
