Unknown Tubes on a 42-327
Not sure if you ever got the answer to 170V at speaker windings........ I assume you are measuring the voltage at the field winding and not the audio output transformer. If there is no load on the B+ supply, then the voltage at the field winding should be close to the PEAK of the line voltage. At 120 VAC input, the peak voltage is 170 Volts (120 x 1.414). This PEAK will be stored in both capacitors around the field coil and will drop as current is drawn. One way to see if the 50L6 is drawing current is to measure the cathode voltage (voltage across the 130 ohm resistor). If the voltage is zero, then no current is flowing.
I also have a Philco 42-327. In the back of the set, attached to a wire that ties to the bank of tuning capacitors is a small sheet metal piece approximately 1.5" x 2". This piece has a hole in it (approx 1/2" dia) with jagged edges and is attached to a cardboard insulator. Does anyone have an idea what this piece is used for and/or where it should be attached. Mine is simply loose inside the back of the radio.
Bob
Unknown Tubes on a 42-327 - by regel_1999 - 03-04-2011, 11:23 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-05-2011, 11:31 AM
Re: Unknown Tubes on a 42-327 - by Carl Travis - 03-05-2011, 11:44 AM
Re: Unknown Tubes on a 42-327 - by BILL - 03-05-2011, 01:46 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-05-2011, 03:28 PM
42-327 with grounds - by regel_1999 - 03-06-2011, 03:19 PM
Re: 42-327 with grounds - by Ron Ramirez - 03-06-2011, 03:45 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 07:26 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-06-2011, 07:51 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:06 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:35 PM
Re: Unknown Tubes on a 42-327 - by DeckApe - 03-07-2011, 02:11 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-07-2011, 09:50 AM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-07-2011, 10:45 AM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-07-2011, 11:24 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-08-2011, 12:49 PM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-08-2011, 04:38 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-08-2011, 04:46 PM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-09-2011, 05:52 PM
Re: Unknown Tubes on a 42-327 - by Ed Locker - 03-10-2011, 10:03 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-10-2011, 07:29 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-14-2011, 12:36 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-14-2011, 10:09 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-16-2011, 02:47 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-16-2011, 06:09 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-16-2011, 10:15 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-17-2011, 11:38 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 12:08 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-17-2011, 01:32 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 08:39 PM
Users browsing this thread: 13 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7237 online users. [Complete List]
» 4 Member(s) | 7233 Guest(s)
AvatarAvatarAvatarAvatar
