Perpetuum Ebner Rex Deluxe alignment
Mike;
  That has to be the oldest set of speakers I have seen with a foam hinge/surround, most of the West German sets I have seen have paper ones just like the majority of North American and British sets would. I didn't think that foam became popular until the 70s, and almost ubiquitous with speakers of the 1980sm though some of the latter were actually a rubber. I'm often though that using leather from a chamois might work as a substitute, but then so would cloth.
Perpetuum Ebner Rex Deluxe alignment - by morzh - 12-21-2020, 04:30 PM
RE: Perpetuum Ebner Rex Deluxe alignment - by Arran - 12-29-2020, 04:25 AM
Eico 232 VTVM Schematic
There are currently 8803 online users. [Complete List]
» 2 Member(s) | 8801 Guest(s)
