  • 2 Vote(s) - 4.5 Average
TrueTone Model D-2026 series B Manual
#70
Tim, yes I'd experiment with some larger values. Remember you're not actually increasing bass but bypassing some of the highs so the lows will seem more pronounced. You're going to be limited by the size (and condition) of your speaker. I'd replace the tone control before futzing around too much with the capacitance since both will effect the tone.
TrueTone Model D-2026 series B Manual - by TTech - 10-04-2020, 12:34 PM
RE: TrueTone Model D-2026 series B Manual - by Eliot Ness - 12-29-2020, 08:40 PM
Users browsing this thread: 13 Guest(s)
There are currently 8482 online users. [Complete List]
» 1 Member(s) | 8481 Guest(s)
