RCA 9X571 Bullhorn - Electrolytic Capacitor
You can place three individual new capacitors in that can after you clean it out (search for electrolytic restuffing), or just mount them under the chassis. Some new cans are made, but they are expensive, and it is unlikely that any now sold have the values you need.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Re: RCA 9X571 Bullhorn - Electrolytic Capacitor - by FStephenMasek - 03-15-2011, 09:56 PM
There are currently 10225 online users. [Complete List]
» 1 Member(s) | 10224 Guest(s)
