Magnavox model 198C restoration
Bill
What did you use to clean the chassis of your Magnavox? Looks good...
I've seen a set like yours before, on eBay. Unusual cabinet. Yeah, I was wondering if you had the phono drawer, since your photos did not show it.
Edit: I have a set of IF transformers pulled from a Maggie chassis like mine (CR-188A). If you need IFs, and if these will work in your set, they're yours for the postage.
Magnavox model 198C restoration - by Bill Cahill - 03-15-2011, 01:35 PM
Re: Magnavox model 198C restoration - by w4rtc - 03-15-2011, 05:23 PM
Re: Magnavox model 198C restoration - by Ron Ramirez - 03-15-2011, 11:13 PM
Re: Magnavox model 198C restoration - by w4rtc - 04-06-2011, 10:16 AM
Re: Magnavox model 198C restoration - by w4rtc - 04-06-2011, 03:33 PM
Philco 91 Tuning Condenser
There are currently 9390 online users. [Complete List]
» 3 Member(s) | 9387 Guest(s)
