Model 90 signatures
Welcome to the Phorum Peter!
Very cool. To me it sure looks like a note from a repair person. I read it as "Replaced tubes. July 17, 1933"
Model 90 signatures - by n1ps - 01-01-2021, 07:05 PM
RE: Model 90 signatures - by Nathan Slingerland - 01-01-2021, 07:18 PM
RE: Model 90 signatures - by n1ps - 01-01-2021, 07:25 PM
RE: Model 90 signatures - by morzh - 01-01-2021, 07:44 PM
RE: Model 90 signatures - by klondike98 - 01-01-2021, 07:47 PM
RE: Model 90 signatures - by Brad Winder - 01-02-2021, 12:00 PM
RE: Model 90 signatures - by Phlogiston - 01-02-2021, 12:18 PM
RE: Model 90 signatures - by RodB - 01-02-2021, 12:22 PM
RE: Model 90 signatures - by madsowry - 01-02-2021, 11:00 PM
RE: Model 90 signatures - by RodB - 01-03-2021, 10:09 AM
RE: Model 90 signatures - by madsowry - 01-03-2021, 12:25 PM
RE: Model 90 signatures - by morzh - 01-03-2021, 12:29 PM
RE: Model 90 signatures - by David - 01-03-2021, 03:14 PM
RE: Model 90 signatures - by Tim Tress - 01-22-2021, 07:56 PM
Philco 91 Tuning Condenser
There are currently 8163 online users. [Complete List]
» 1 Member(s) | 8162 Guest(s)
