I now have a 15X
Nice going, you have discipline and a Knack for obtaining real neat sets.
I have a 15X too, by a differrent maker Icon_smile.
[Image: https://capeoldradio.com/cor_picts/RCA%2...553-P1.jpg]Paul
I now have a 15X - by rdnzl - 01-02-2021, 04:32 PM
RE: I now have a 15X - by Paul Philco322 - 01-02-2021, 04:50 PM
RE: I now have a 15X - by RadioSvit - 01-02-2021, 04:51 PM
RE: I now have a 15X - by Brad Winder - 01-02-2021, 05:49 PM
RE: I now have a 15X - by rdnzl - 01-02-2021, 06:46 PM
RE: I now have a 15X - by morzh - 01-02-2021, 07:21 PM
RE: I now have a 15X - by Phlogiston - 01-02-2021, 08:00 PM
RE: I now have a 15X - by rfeenstra - 01-03-2021, 06:35 PM
Philco 91 Tuning Condenser
There are currently 8468 online users. [Complete List]
» 2 Member(s) | 8466 Guest(s)
