Unknown Tubes on a 42-327
rplackey Wrote:I also have a Philco 42-327. In the back of the set, attached to a wire that ties to the bank of tuning capacitors is a small sheet metal piece approximately 1.5" x 2". This piece has a hole in it (approx 1/2" dia) with jagged edges and is attached to a cardboard insulator. Does anyone have an idea what this piece is used for and/or where it should be attached. Mine is simply loose inside the back of the radio.
Bob
I just looked inside my 42-327, and mine does not have anything like you describe. Perhaps you could share a photo?
Unknown Tubes on a 42-327 - by regel_1999 - 03-04-2011, 11:23 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-05-2011, 11:31 AM
Re: Unknown Tubes on a 42-327 - by Carl Travis - 03-05-2011, 11:44 AM
Re: Unknown Tubes on a 42-327 - by BILL - 03-05-2011, 01:46 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-05-2011, 03:28 PM
42-327 with grounds - by regel_1999 - 03-06-2011, 03:19 PM
Re: 42-327 with grounds - by Ron Ramirez - 03-06-2011, 03:45 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 07:26 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-06-2011, 07:51 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:06 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:35 PM
Re: Unknown Tubes on a 42-327 - by DeckApe - 03-07-2011, 02:11 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-07-2011, 09:50 AM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-07-2011, 10:45 AM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-07-2011, 11:24 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-08-2011, 12:49 PM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-08-2011, 04:38 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-08-2011, 04:46 PM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-09-2011, 05:52 PM
Re: Unknown Tubes on a 42-327 - by Ed Locker - 03-10-2011, 10:03 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-10-2011, 07:29 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-14-2011, 12:36 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-14-2011, 10:09 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-16-2011, 02:47 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-16-2011, 06:09 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-16-2011, 10:15 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-17-2011, 11:38 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 12:08 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-17-2011, 01:32 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 08:39 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7484 online users. [Complete List]
» 3 Member(s) | 7481 Guest(s)
