Model 90 signatures
If you know someone who is a LEO ask if the local department can scan the prints and run them. Long shot but if anyone had a security clearance in the past there prints will still be on file and is now digital will only take a hour or two to get a answer. Nice find David
Model 90 signatures - by n1ps - 01-01-2021, 07:05 PM
RE: Model 90 signatures - by Nathan Slingerland - 01-01-2021, 07:18 PM
RE: Model 90 signatures - by n1ps - 01-01-2021, 07:25 PM
RE: Model 90 signatures - by morzh - 01-01-2021, 07:44 PM
RE: Model 90 signatures - by klondike98 - 01-01-2021, 07:47 PM
RE: Model 90 signatures - by Brad Winder - 01-02-2021, 12:00 PM
RE: Model 90 signatures - by Phlogiston - 01-02-2021, 12:18 PM
RE: Model 90 signatures - by RodB - 01-02-2021, 12:22 PM
RE: Model 90 signatures - by madsowry - 01-02-2021, 11:00 PM
RE: Model 90 signatures - by RodB - 01-03-2021, 10:09 AM
RE: Model 90 signatures - by madsowry - 01-03-2021, 12:25 PM
RE: Model 90 signatures - by morzh - 01-03-2021, 12:29 PM
RE: Model 90 signatures - by David - 01-03-2021, 03:14 PM
RE: Model 90 signatures - by Tim Tress - 01-22-2021, 07:56 PM
Philco 91 Tuning Condenser
There are currently 6842 online users. [Complete List]
» 2 Member(s) | 6840 Guest(s)
