Philco model 70?
The sw on the back looks to the tone control. And up front is some sort of switching for the oscillator circuit.
Philco model 70? - by Mikeym53 - 01-04-2021, 01:33 PM
RE: Philco model 70? - by Radioroslyn - 01-04-2021, 04:14 PM
RE: Philco model 70? - by morzh - 01-04-2021, 09:38 PM
RE: Philco model 70? - by Brad Winder - 01-06-2021, 01:24 AM
RE: Philco model 70? - by radiorich - 01-06-2021, 02:26 AM
RE: Philco model 70? - by Mikeym53 - 01-06-2021, 09:29 PM
There are currently 10126 online users. [Complete List]
» 1 Member(s) | 10125 Guest(s)
