RCA 9X571 Bullhorn - Electrolytic Capacitor
You can save a little bit of trouble by mounting the new 40@25v directly at the audio output tube. The modern caps are so small!
Re: RCA 9X571 Bullhorn - Electrolytic Capacitor - by exray - 03-16-2011, 09:12 PM
Eico 232 VTVM Schematic
There are currently 8786 online users. [Complete List]
» 2 Member(s) | 8784 Guest(s)
