Philco model 70?
Could it possibly be a 70 chassis made to pair with the model 4 SW converter? I'm assuming the 70s and 90s that came with the SW converter built into the same cabinet would have a few differences in the chassis?
Philco model 70? - by Mikeym53 - 01-04-2021, 01:33 PM
RE: Philco model 70? - by Radioroslyn - 01-04-2021, 04:14 PM
RE: Philco model 70? - by morzh - 01-04-2021, 09:38 PM
RE: Philco model 70? - by Brad Winder - 01-06-2021, 01:24 AM
RE: Philco model 70? - by radiorich - 01-06-2021, 02:26 AM
RE: Philco model 70? - by Mikeym53 - 01-06-2021, 09:29 PM
There are currently 9818 online users. [Complete List]
» 1 Member(s) | 9817 Guest(s)
