1937 Coronado Model 650 Farm Radio
#34
You may have nailed it, power switch........does any current get into the circuit when switch open?
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 05:43 PM
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 06:03 PM
RE: 1930s Coronado Farm Radio - by David - 11-25-2020, 06:56 PM
RE: 1930s Coronado Farm Radio - by Arran - 11-25-2020, 10:36 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-25-2020, 11:48 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 10:00 AM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 01:02 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 03:56 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-27-2020, 03:03 AM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-28-2020, 04:30 AM
RE: 1937 Coronado Model 650 Farm Radio - by RodB - 01-01-2021, 10:16 AM
RE: 1937 Coronado Model 650 Farm Radio - by Paul Philco322 - 01-08-2021, 08:50 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 01-08-2021, 09:11 PM
