Shadow Meter 37-630 console
Is the Shadow Meter lamp aligned properly to shine into the Shadow Meter?
No light - no shadow - dark screen. You would not see any shadow width chages.
See my Service Tips section on the Shadow Meter adjustments and repair.
Chuck
Shadow Meter 37-630 console - by douglasreid - 04-24-2011, 01:38 PM
Re: Shadow Meter 37-630 console - by Steve Davis - 04-24-2011, 03:53 PM
Re: Shadow Meter 37-630 console - by douglasreid - 05-04-2011, 10:44 AM
Re: Shadow Meter 37-630 console - by Chuck Schwark - 05-04-2011, 10:49 AM
Re: Shadow Meter 37-630 console - by douglasreid - 05-04-2011, 10:44 PM
The speaker table error?
Philco 70 antenna lead
