Help with a model...
Hi,
Quite a coincidence, since I saw one of these just this past weekend at a barn sale in Arlington, MA. I was tempted to buy it, but it had some missing/separated veneer (though not as bad as the one pictured here) as well as some deep scratches/gouges down into the veneer. With the guy firm at $60 I passed on it. Somehow I've got more than enough project radios sitting around and I stayed firm on my decision and left before I changed my mind. However, on a weaker day I may well have given in to that little inner voice calling upon me to "rescue it" and would have dragged it on home. Great radios when done up.
Help with a model... - by Guest - 03-01-2006, 05:45 PM
[No subject] - by Chuck Schwark - 03-01-2006, 07:36 PM
[No subject] - by 49Stude63 - 03-01-2006, 09:56 PM
[No subject] - by Chuck Schwark - 03-01-2006, 10:46 PM
[No subject] - by 49Stude63 - 03-02-2006, 03:38 PM
[No subject] - by Guest - 03-24-2006, 05:01 PM
[No subject] - by PTurney - 03-24-2006, 06:53 PM
[No subject] - by Guest - 04-11-2006, 03:08 PM
[No subject] - by Chuck Schwark - 04-11-2006, 07:01 PM
Philco 91 Tuning Condenser
There are currently 6892 online users. [Complete List]
» 2 Member(s) | 6890 Guest(s)
