Chev model B47 car radio
Hi Radioroslyn, Thanks for that index.Now we will know where to go for info on stuff post 1947 or at least which volume of Sams we're hoping to find. As you say still in copyright but helpful to know where to look. Thanks again. Cheers
Chev model B47 car radio - by Antipodal - 01-09-2021, 05:46 AM
RE: Chev model B47 car radio - by Radioroslyn - 01-09-2021, 04:16 PM
RE: Chev model B47 car radio - by Antipodal - 01-09-2021, 07:35 PM
RE: Chev model B47 car radio - by RodB - 01-09-2021, 08:22 PM
RE: Chev model B47 car radio - by Antipodal - 01-09-2021, 10:35 PM
RE: Chev model B47 car radio - by Antipodal - 01-09-2021, 10:49 PM
RE: Chev model B47 car radio - by Radioroslyn - 01-09-2021, 11:20 PM
RE: Chev model B47 car radio - by Antipodal - 01-10-2021, 12:05 AM
RE: Chev model B47 car radio - by Radioroslyn - 01-10-2021, 07:19 AM
