Crosley 158 Septet
Hello, John: they are fairly uncommon from my perspective. They are a decent reciever but can be a pain in the thing you sit on to restore both electrically and cabinet-wise. If this one is in decent shape and not overly pricey I would grab it.
The reason I say that the cabinets are tough is that the wood lamination often bubbles and separates, and often the wood on the arch splits along the wood grain.
Crosley 158 Septet - by John R - 03-17-2011, 12:14 PM
Re: Crosley 158 Septet - by TA Forbes - 03-17-2011, 04:24 PM
Re: Crosley 158 Septet - by TA Forbes - 03-21-2011, 11:17 PM
Re: Crosley 158 Septet - by John R - 03-22-2011, 01:38 PM
There are currently 4655 online users. [Complete List]
» 1 Member(s) | 4654 Guest(s)
