Philco 116X tone control (Solved!)
Lol! I am in the midst of restoring my 3116X...I guess I'll learn the tone control when I get to it.
Have you contacted your radio station? They may have an issue that they don't know about...
Philco 116X tone control (Solved!) - by Jayce - 01-09-2021, 03:54 PM
RE: Philco 116X tone control (Solved!) - by Brad Winder - 01-16-2021, 02:38 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-16-2021, 03:42 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-16-2021, 07:05 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-17-2021, 05:14 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-19-2021, 04:58 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-19-2021, 05:23 PM
Philco 91 Tuning Condenser
There are currently 9208 online users. [Complete List]
» 1 Member(s) | 9207 Guest(s)
