Philco 116X tone control (Solved!)
Jayce FWIW, I’ve noticed a long time ago my radios with built in loop antennas seem to out perform any of my long wire sets. Both for sensitivity and noise reduction.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Philco 116X tone control (Solved!) - by Jayce - 01-09-2021, 03:54 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-16-2021, 03:42 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-16-2021, 07:05 PM
RE: Philco 116X tone control (Solved!) - by 462ron - 01-17-2021, 12:20 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-17-2021, 05:14 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-19-2021, 04:58 PM
RE: Philco 116X tone control (Solved!) - by Jayce - 01-19-2021, 05:23 PM
There are currently 8422 online users. [Complete List]
» 1 Member(s) | 8421 Guest(s)
