AS4 Hobbyists Radio
My latest revision of the schematic is based on a realization that the rotor on the variable capacitor is common to both the broadcast portion and the oscillator portion. The previous design would not have worked. It would have shorted the AGC circuit.
AS4 Hobbyists Radio - by Daniel Bingamon - 12-24-2020, 04:18 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 12-24-2020, 04:19 PM
RE: AS4 Hobbyists Radio - by RodB - 12-24-2020, 06:27 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 12-24-2020, 07:48 PM
RE: AS4 Hobbyists Radio - by Radioroslyn - 12-24-2020, 09:22 PM
RE: AS4 Hobbyists Radio - by vinzer - 12-24-2020, 09:28 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 12-30-2020, 11:24 PM
RE: AS4 Hobbyists Radio - by Arran - 12-31-2020, 04:48 AM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 01-15-2021, 08:37 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 01-17-2021, 05:12 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 01-24-2021, 03:49 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 05-16-2021, 10:50 AM
RE: AS4 Hobbyists Radio - by OZ4 - 05-16-2021, 01:21 PM
RE: AS4 Hobbyists Radio - by Daniel Bingamon - 09-19-2021, 01:48 PM
There are currently 7426 online users. [Complete List]
» 1 Member(s) | 7425 Guest(s)
