Help With the King's Radio UPDATED HISTORY
Paul,
You may have missed the picture of the "replacement" radio which is very cool.
I did not post it until 10 min after the initial entry - your time stamp is only 6 min later so you probably did.
My fingers are just not fast enough - anymore.
RE: Help With the King's Radio - by morzh - 01-15-2021, 03:22 PM
RE: Help With the King's Radio - by Phlogiston - 01-15-2021, 03:33 PM
RE: Help With the King's Radio - by morzh - 01-15-2021, 05:04 PM
RE: Help With the King's Radio - by Phlogiston - 01-15-2021, 05:17 PM
RE: Help With the King's Radio - by Eliot Ness - 01-15-2021, 05:56 PM
RE: Help With the King's Radio - by Jayce - 01-15-2021, 08:17 PM
RE: Help With the King's Radio - by Ron Ramirez - 01-15-2021, 10:56 PM
RE: Help With the King's Radio - by patrician56 - 01-16-2021, 12:06 AM
RE: Help With the King's Radio - by Phlogiston - 01-16-2021, 10:42 AM
RE: Help With the King's Radio UPDATED HISTORY - by Phlogiston - 01-18-2021, 12:04 PM
There are currently 5818 online users. [Complete List]
» 2 Member(s) | 5816 Guest(s)
