Another National SW-54
I meant to say an NC-125, not 71. Getting drifty in my old age. This is a picture of it as received, it's from the eBay listing. I picked it up VERY reasonable. Sometimes you do find a bargain there.
[Image: https://64.media.tumblr.com/7f56a0296e9b...922566.jpg]
Another National SW-54 - by mikethedruid - 01-18-2021, 09:58 PM
RE: Another National SW-54 - by Radioroslyn - 01-18-2021, 10:59 PM
RE: Another National SW-54 - by mikethedruid - 01-19-2021, 12:17 AM
RE: Another National SW-54 - by radiorich - 01-19-2021, 09:51 PM
RE: Another National SW-54 - by mikethedruid - 01-19-2021, 11:14 PM
RE: Another National SW-54 - by Arran - 01-20-2021, 02:47 PM
RE: Another National SW-54 - by mikethedruid - 01-20-2021, 07:04 PM
There are currently 4558 online users. [Complete List]
» 1 Member(s) | 4557 Guest(s)
