Another National SW-54
Hello mike,
what nice set and I see you have put a lot work into .
I am currently working on a zenith Model 908 had to replaced all the capacitors .
I stuffed new capacitors in the old shells .
Sincerely Rich
Another National SW-54 - by mikethedruid - 01-18-2021, 09:58 PM
RE: Another National SW-54 - by Radioroslyn - 01-18-2021, 10:59 PM
RE: Another National SW-54 - by mikethedruid - 01-19-2021, 12:17 AM
RE: Another National SW-54 - by radiorich - 01-19-2021, 09:51 PM
RE: Another National SW-54 - by mikethedruid - 01-19-2021, 11:14 PM
RE: Another National SW-54 - by Arran - 01-20-2021, 02:47 PM
RE: Another National SW-54 - by mikethedruid - 01-20-2021, 07:04 PM
Philco 91 Tuning Condenser
There are currently 10431 online users. [Complete List]
» 2 Member(s) | 10429 Guest(s)
