Old Philco Radio Id Help Needed ( Please)
https://philcoradio.com/gallery2/1942a/#Model_42-1009P
Please contact Nathan Slingerland here on the Phorum if you wish to furnish photographs of your radio to the Gallery which could use some good shots of one like yours. You will see in the link above that the set in the Gallery has drapery fabric instead of the original grille cloth.
RE: Old Philco Radio Id Help Needed ( Please) - by Ron Ramirez - 01-20-2021, 10:55 PM
Philco 91 Tuning Condenser
There are currently 9069 online users. [Complete List]
» 2 Member(s) | 9067 Guest(s)
