Help to id Philco condenser block
gvel Wrote:I can't answer your capacitor question, but I have a comment on the resistor reading high.
When you measured this, was one end of the resistor disconnected from the circuit? Since it's across a capacitor, you will get "goofy" measurements, if one end of the resistor is not lifted. Wire wound resistors usually don't drift too much. They are usually good or open, but nothing's impossible.
Yes...no harm buying line capacitors...when you make your order!
Greg-
Yes, one end of resistor was lifted when measuring--I like you have generally found wire wounds to fail open, but this one reads 1.6K; it has obviously developed an internal fault.
Kico
Best regards,
Kico
"I whisper, but my horse still doesn't listen."
Help to id Philco condenser block - by Kico - 03-17-2011, 05:53 PM
Re: Help to id Philco condenser block - by gvel - 03-17-2011, 06:19 PM
Re: Help to id Philco condenser block - by Kico - 03-17-2011, 10:09 PM
Re: Help to id Philco condenser block - by Kico - 03-19-2011, 08:31 AM
Re: Help to id Philco condenser block - by gvel - 03-19-2011, 10:36 AM
Re: Help to id Philco condenser block - by Kico - 03-19-2011, 11:09 AM
Re: Help to id Philco condenser block - by Kico - 03-19-2011, 05:15 PM
Re: Help to id Philco condenser block - by exray - 03-20-2011, 06:58 AM
Re: Help to id Philco condenser block - by Kico - 03-20-2011, 08:38 AM
Re: Help to id Philco condenser block - by Kico - 03-22-2011, 04:39 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5144 online users. [Complete List]
» 3 Member(s) | 5141 Guest(s)
