41-608 off- on switch
It's called a latching switch. Some rebuild the old one and other replace it. I've replaced a few.
https://www.philcoradio.com/phorum/showt...php?tid=89
Might be handy to immortalize this post in the Library.
41-608 off- on switch - by Forrest - 01-24-2021, 09:31 PM
RE: 41-608 off- on switch - by Radioroslyn - 01-24-2021, 09:40 PM
RE: 41-608 off- on switch - by Forrest - 01-25-2021, 08:41 AM
RE: 41-608 off- on switch - by Art Hoch - 01-27-2021, 01:58 PM
Philco 91 Tuning Condenser
There are currently 8850 online users. [Complete List]
» 3 Member(s) | 8847 Guest(s)
