here is another one i need to id philco
Just take a look through the Philco Radio Gallery.
https://philcoradio.com/gallery2/1938a/#Model_38-2XX
Whoomp, there it is.
RE: here is another one i need to id philco - by Ron Ramirez - 01-25-2021, 12:15 AM
There are currently 10523 online users. [Complete List]
» 1 Member(s) | 10522 Guest(s)
