here is another one i need to id philco
The 38-2 used the Philco "Ribbed" pattern originally, mounted vertically (up and down). Not the chevron cloth.
RE: here is another one i need to id philco - by Ron Ramirez - 01-25-2021, 12:24 AM
There are currently 6838 online users. [Complete List]
» 2 Member(s) | 6836 Guest(s)
