Restoration of 71H
I too rebuild radios in the UK but to recap a vintage set with obvious yellow poly caps is a shame. It doesn't take much to restuff the originals.
If we can find some old originals or even good photos of the capacitors new sleeves could be made.
Does the set work OK?
I don't know where you are located, I am in Cheshire around Middlewich if I can help.
Sam.
PS PM me if I can be of assistance, I don't get here often. Sam.
Restoration of 71H - by Tryweryn - 01-27-2021, 11:45 PM
RE: Restoration of 71H - by Radioroslyn - 01-28-2021, 08:48 AM
RE: Restoration of 71H - by Tryweryn - 01-28-2021, 10:22 AM
RE: Restoration of 71H - by Radioroslyn - 01-28-2021, 02:59 PM
RE: Restoration of 71H - by Arran - 01-28-2021, 10:27 PM
RE: Restoration of 71H - by Brad Winder - 01-29-2021, 10:02 AM
RE: Restoration of 71H - by Boater Sam - 01-29-2021, 12:23 PM
RE: Restoration of 71H - by govee - 01-29-2021, 10:09 PM
RE: Restoration of 71H - by Arran - 02-01-2021, 04:26 AM
RE: Restoration of 71H - by Tryweryn - 01-21-2023, 03:29 PM
RE: Restoration of 71H - by Radioroslyn - 01-21-2023, 05:31 PM
Philco 91 Tuning Condenser
