Scott SLRM
The SLRM I purchase from Ron and rebuilt has a 3 prong, polarized plug, so no problem. It has been a while, but I seem to remember testing this radio for high voltage on the chassis with various plug connections, and could find none. None the less, it pays to be cautious! Great radio!!!
Scott SLRM - by mikethedruid - 01-31-2021, 05:00 PM
RE: Scott SLRM - by rfeenstra - 01-31-2021, 10:49 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 06:43 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:30 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:36 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 08:03 PM
RE: Scott SLRM - by Paul Philco322 - 02-02-2021, 08:09 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 10:14 PM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:00 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:27 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 01:48 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 02:24 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 03:23 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 11:45 AM
RE: Scott SLRM - by mikethedruid - 02-04-2021, 06:45 PM
RE: Scott SLRM - by Eliot Ness - 02-04-2021, 08:11 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 12:31 AM
RE: Scott SLRM - by morzh - 02-06-2021, 01:33 AM
RE: Scott SLRM - by rfeenstra - 02-06-2021, 12:28 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 02:45 PM
RE: Scott SLRM - by Ron Ramirez - 02-06-2021, 02:56 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 07:57 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 05:27 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 09:24 PM
RE: Scott SLRM - by mikethedruid - 02-09-2021, 12:03 AM
RE: Scott SLRM - by rfeenstra - 02-09-2021, 12:51 AM
RE: Scott SLRM - by mikethedruid - 02-10-2021, 09:54 PM
RE: Scott SLRM - by mikethedruid - 02-11-2021, 09:22 PM
RE: Scott SLRM - by mikethedruid - 02-18-2021, 09:27 PM
RE: Scott SLRM - by mikethedruid - 02-24-2021, 11:52 PM
RE: Scott SLRM - by Eliot Ness - 02-25-2021, 12:19 PM
RE: Scott SLRM - by mikethedruid - 02-26-2021, 12:14 AM
There are currently 8884 online users. [Complete List]
» 1 Member(s) | 8883 Guest(s)
