1929 Philco model 87 lowboy cabinet questions
Thank you for your responses, compliments, and info! I was aware the later versions were made without the grille insert. I like the way it looks and I'm up for the challenge. Never tried using a scroll saw before, so we'll see how it goes.
Anyone ever seen such a mis-aligned molding at the bottom of the speaker opening? It's actually the "bird's eye" center panel that was installed crooked.
RE: 1929 Philco model 87 lowboy cabinet questions - by 62fender - 02-01-2021, 12:57 PM
