Need help ID'ing console ('29 Model 65?)
Well, I've rounded up the bits for the chassis and am trying to sort it out. The #3 center tap to the 80 tube was gone on the main power transformer; I located a used replacement which is now in place.
There's some funky wiring running to the 80 tube that doesn't match the schematic. The #1 and #2 from the xfrmer are supposed to go to the heater for the 80, with #1 from xfrmer running over to the condenser block. #4 and 5 on the xfrmer go to the other side of the tube, with #3 (the center tap) going to ground.
On this radio, #1 and #2 are wired to the 80, but that's it. The #4 and #5 are wired to the 80, but the #5 goes to the condenser block, rather than the #1.
Follow all that? Maybe a way to keep it working with an open #3 center tap?
Question is, should I rewire it back to original, or leave it alone?
[No subject] - by Chuck Schwark - 01-31-2006, 12:21 AM
[No subject] - by noiseguy - 01-31-2006, 09:55 AM
[No subject] - by Ron Ramirez - 01-31-2006, 09:59 AM
[No subject] - by Chuck Schwark - 01-31-2006, 10:03 AM
[No subject] - by Ron Ramirez - 01-31-2006, 01:06 PM
[No subject] - by rjm - 01-31-2006, 03:33 PM
[No subject] - by noiseguy - 02-01-2006, 11:40 PM
[No subject] - by Chuck Schwark - 02-01-2006, 11:52 PM
[No subject] - by noiseguy - 02-02-2006, 05:09 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:44 PM
[No subject] - by noiseguy - 02-17-2006, 01:09 PM
[No subject] - by rjm - 02-17-2006, 02:15 PM
[No subject] - by noiseguy - 03-27-2006, 12:45 AM
[No subject] - by rjm - 03-27-2006, 02:01 AM
[No subject] - by noiseguy - 03-27-2006, 09:12 AM
[No subject] - by noiseguy - 03-27-2006, 09:34 AM
Eico 232 VTVM Schematic
There are currently 6737 online users. [Complete List]
» 1 Member(s) | 6736 Guest(s)
