Another noob with another Philco!
Hi Larry, I have a Jackson 648s Tester too, I had an updates tube chart, but can't seem to find it after the move, do you have a copy of it? Thanks
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
RE: Another noob with another Philco! - by David - 12-12-2018, 09:34 AM
RE: Another noob with another Philco! - by morzh - 12-12-2018, 11:18 AM
Tube testing - by atlghosthunter - 01-05-2019, 04:27 AM
RE: Another noob with another Philco! - by nortonz - 02-02-2021, 05:49 PM
Philco 91 Tuning Condenser
There are currently 8824 online users. [Complete List]
» 2 Member(s) | 8822 Guest(s)
