Scott SLRM
Well, here goes nothin' ! I lugged the Scott onto my work bench. I had forgotten how HEAVY it is ! Boat anchor ain't in it! This thing, in its case outweighs my Hammarlunds, let alone my National ! It came in a very nice, and heavy, steel case which holds the rack mount radio itself. Here are the first pictures of the set on my bench, first, as received, still in its case, then removed from the case....
[Image: https://64.media.tumblr.com/ffb53a0b1f8b...52327a.jpg]
[Image: https://64.media.tumblr.com/2dfaf825bb09...5c83bd.jpg]
[Image: https://64.media.tumblr.com/bafe77d24688...879354.jpg]
[Image: https://64.media.tumblr.com/3be95dc1611e...b38f94.jpg]
[Image: https://64.media.tumblr.com/c47b5b27317e...5a193e.jpg]
Scott SLRM - by mikethedruid - 01-31-2021, 05:00 PM
RE: Scott SLRM - by rfeenstra - 01-31-2021, 10:49 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 06:43 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:30 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:36 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 08:03 PM
RE: Scott SLRM - by Paul Philco322 - 02-02-2021, 08:09 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 10:14 PM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:00 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:27 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 01:48 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 02:24 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 03:23 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 11:45 AM
RE: Scott SLRM - by mikethedruid - 02-04-2021, 06:45 PM
RE: Scott SLRM - by Eliot Ness - 02-04-2021, 08:11 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 12:31 AM
RE: Scott SLRM - by morzh - 02-06-2021, 01:33 AM
RE: Scott SLRM - by rfeenstra - 02-06-2021, 12:28 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 02:45 PM
RE: Scott SLRM - by Ron Ramirez - 02-06-2021, 02:56 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 07:57 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 05:27 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 09:24 PM
RE: Scott SLRM - by mikethedruid - 02-09-2021, 12:03 AM
RE: Scott SLRM - by rfeenstra - 02-09-2021, 12:51 AM
RE: Scott SLRM - by mikethedruid - 02-10-2021, 09:54 PM
RE: Scott SLRM - by mikethedruid - 02-11-2021, 09:22 PM
RE: Scott SLRM - by mikethedruid - 02-18-2021, 09:27 PM
RE: Scott SLRM - by mikethedruid - 02-24-2021, 11:52 PM
RE: Scott SLRM - by Eliot Ness - 02-25-2021, 12:19 PM
RE: Scott SLRM - by mikethedruid - 02-26-2021, 12:14 AM
There are currently 4219 online users. [Complete List]
» 1 Member(s) | 4218 Guest(s)
