Scott SLRM
I didn't do much with the Scott today. I just tested the 1629 magic eye tube. Fortunately my Simpson lists it in the appendix part of the lists, and tests it completely. Nice bright eye! tests good, which is fortunate. I have bought another just to have on hand. All the other tubes I already have. Lately I have been testing tubes I collected over the years.... HUNDREDS of them. Most of them are good. Maybe 10% are bad, or have no legible type markings. I've had to buy a LOT of boxes for them. LOL! but they are all boxed and labelled. I just pray that when I'm gone my foster son finds them a good home, or sells them to someone who will want them. They are worth a LOT of money, even if you just figure the average value at $5 apiece.
Scott SLRM - by mikethedruid - 01-31-2021, 05:00 PM
RE: Scott SLRM - by rfeenstra - 01-31-2021, 10:49 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 06:43 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:30 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:36 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 08:03 PM
RE: Scott SLRM - by Paul Philco322 - 02-02-2021, 08:09 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 10:14 PM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:00 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:27 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 01:48 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 02:24 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 03:23 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 11:45 AM
RE: Scott SLRM - by mikethedruid - 02-04-2021, 06:45 PM
RE: Scott SLRM - by Eliot Ness - 02-04-2021, 08:11 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 12:31 AM
RE: Scott SLRM - by morzh - 02-06-2021, 01:33 AM
RE: Scott SLRM - by rfeenstra - 02-06-2021, 12:28 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 02:45 PM
RE: Scott SLRM - by Ron Ramirez - 02-06-2021, 02:56 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 07:57 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 05:27 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 09:24 PM
RE: Scott SLRM - by mikethedruid - 02-09-2021, 12:03 AM
RE: Scott SLRM - by rfeenstra - 02-09-2021, 12:51 AM
RE: Scott SLRM - by mikethedruid - 02-10-2021, 09:54 PM
RE: Scott SLRM - by mikethedruid - 02-11-2021, 09:22 PM
RE: Scott SLRM - by mikethedruid - 02-18-2021, 09:27 PM
RE: Scott SLRM - by mikethedruid - 02-24-2021, 11:52 PM
RE: Scott SLRM - by Eliot Ness - 02-25-2021, 12:19 PM
RE: Scott SLRM - by mikethedruid - 02-26-2021, 12:14 AM
There are currently 5725 online users. [Complete List]
» 2 Member(s) | 5723 Guest(s)
