Scott SLRM
The two single condenser cans are $32.95 each and the double condenser cans are $33.95 each. Shipping to me will be $9.50. I know that may seem steep to some people, but this gives me un-molested new can condensers, I don't have to cut open and re-stuff anything, and, having seen their work before, I am sure they will be correct in dimensions and as close to the originals as they can make them. I consider the cost very reasonable. The versions they make a lot of are less expensive. These are one of a kind at present, completely custom. It is great to have a resource like them.
Scott SLRM - by mikethedruid - 01-31-2021, 05:00 PM
RE: Scott SLRM - by rfeenstra - 01-31-2021, 10:49 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 06:43 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:30 PM
RE: Scott SLRM - by rfeenstra - 02-02-2021, 07:36 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 08:03 PM
RE: Scott SLRM - by Paul Philco322 - 02-02-2021, 08:09 PM
RE: Scott SLRM - by mikethedruid - 02-02-2021, 10:14 PM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:00 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 01:27 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 01:48 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 02:24 AM
RE: Scott SLRM - by mikethedruid - 02-03-2021, 03:23 AM
RE: Scott SLRM - by rfeenstra - 02-03-2021, 11:45 AM
RE: Scott SLRM - by mikethedruid - 02-04-2021, 06:45 PM
RE: Scott SLRM - by Eliot Ness - 02-04-2021, 08:11 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 12:31 AM
RE: Scott SLRM - by morzh - 02-06-2021, 01:33 AM
RE: Scott SLRM - by rfeenstra - 02-06-2021, 12:28 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 02:45 PM
RE: Scott SLRM - by Ron Ramirez - 02-06-2021, 02:56 PM
RE: Scott SLRM - by mikethedruid - 02-06-2021, 07:57 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 05:27 PM
RE: Scott SLRM - by mikethedruid - 02-08-2021, 09:24 PM
RE: Scott SLRM - by mikethedruid - 02-09-2021, 12:03 AM
RE: Scott SLRM - by rfeenstra - 02-09-2021, 12:51 AM
RE: Scott SLRM - by mikethedruid - 02-10-2021, 09:54 PM
RE: Scott SLRM - by mikethedruid - 02-11-2021, 09:22 PM
RE: Scott SLRM - by mikethedruid - 02-18-2021, 09:27 PM
RE: Scott SLRM - by mikethedruid - 02-24-2021, 11:52 PM
RE: Scott SLRM - by Eliot Ness - 02-25-2021, 12:19 PM
RE: Scott SLRM - by mikethedruid - 02-26-2021, 12:14 AM
