38-2 cabinet finish, what did they use originally
NO! Do not use that stuff on bare wood! If the cabinet needs to be refinished, do it right and refinish it using sanding sealer, grain filler, toning lacquer, and clear lacquer.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8832 online users. [Complete List]
» 3 Member(s) | 8829 Guest(s)
