EH Scott Philharmonic AM/FM
Threads: 49
City: Allendale, MI
Thanks Mike! I've seen a couple of those articles in my investigation. I've even tried to PM Penthode to see if he is still converting the "subbers" I have 2 that I would like converted. Or, I'll learn to do it myself. That system, along with the ordinary TV tuner appears to be the better, more sensitive solution. For now, I'll use the one I purchased from Bill on the Scott site. It could be fun to experiment with the subbers I have.
RE: EH Scott Philharmonic AM/FM - by rfeenstra - 02-14-2021, 01:06 PM
Users browsing this thread: 20 Guest(s)
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
There are currently 10615 online users. [Complete List] » 1 Member(s) | 10614 Guest(s)
