Use old existing wires or rewire, Model 65
If you can slip a clear piece of shrink tube on the wire, I would. If not I guess, it is a judgment call. I try to not replace, but if it means safety, I will. My 87 and 77 have 99% of their original wires. I shrink tubed some wires and replaced some to the coils with original style black cotton push back wire, found at Antique Radio Supply. Good Luck.
Richard
[No subject] - by rjm - 03-27-2006, 01:21 AM
[No subject] - by Frank - 03-28-2006, 10:13 AM
