How do you digitally organize your Philco collection?
Save to Cloud? I am sure you will find a solution works for you. I knew one old timer kept a packet on each set, schematic, notes on work done, wrote on outside when acquired, where, from who, etc, kept them in a file like a dossier on each set, if he worked on one again more notes and into packet. If you got a set from him you got the info too.
Or just put them in the basement, wonder where they are, what you did with it, is it upstairs, did I sell it? Surely I jestIcon_smile.
There are currently 10882 online users. [Complete List]
» 2 Member(s) | 10880 Guest(s)
