Philco 41-629 - Wire connections
Thank you all for your input and advice. Too bad there isn't a kit with all the parts that need to be upgraded!
Anyone have a list of all the capacitors (condensers) modern part cross? I would lie to just order everything in one whack. I want to keep the tubes and general original function, but I'm ok upgrading the old leaky and antiquated capacitors for modern ones.
I can run through all the resistors and make sure they are within tolerance (+/- 5%?)
This one doesn't have the light wave thing in the phonograph, looks like standard wired cartridge.
There is also an RCA style jack wired in, I'm thinking audio input?
Anyway, I have much to learn, and I'm so very grateful to have found this phorum!
Philco 41-629 - Wire connections - by mhuppertz - 02-20-2021, 11:24 AM
RE: Philco 41-629 - Wire connections - by RodB - 02-20-2021, 06:31 PM
RE: Philco 41-629 - Wire connections - by RodB - 02-20-2021, 06:50 PM
RE: Philco 41-629 - Wire connections - by mhuppertz - 02-20-2021, 11:32 PM
RE: Philco 41-629 - Wire connections - by RodB - 02-21-2021, 10:31 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
