Philco 43 - Filter Choke
Speaker was plugged in so that was easy.  Found a loose wire and start to get B voltage readings. I attached the readings up to the 1st Det (tube 44)  .  Then a new problem the wire resistor (item 57) part # 6450 started to heat up and smoke. Unplugged and called it a night.   So can you look at the attached reading a let me know what you think and what should a do with the wire resistor.  Having a hard time giving up on this the cabinet restoration came out perfect just need the radio now
Philco 43 - Filter Choke - by Masonparker - 02-13-2021, 06:16 PM
RE: Philco 43 - Filter Choke - by Radioroslyn - 02-13-2021, 06:43 PM
RE: Philco 43 - Filter Choke - by morzh - 02-13-2021, 09:07 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-21-2021, 08:08 PM
RE: Philco 43 - Filter Choke - by Radioroslyn - 02-21-2021, 08:49 PM
RE: Philco 43 - Filter Choke - by morzh - 02-21-2021, 10:43 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-22-2021, 09:14 PM
RE: Philco 43 - Filter Choke - by morzh - 02-22-2021, 10:06 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-22-2021, 10:12 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-22-2021, 10:15 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-22-2021, 10:59 PM
RE: Philco 43 - Filter Choke - by morzh - 02-22-2021, 11:22 PM
RE: Philco 43 - Filter Choke - by Masonparker - 02-23-2021, 07:58 PM
RE: Philco 43 - Filter Choke - by Radioroslyn - 02-23-2021, 08:36 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-18-2021, 06:52 PM
RE: Philco 43 - Filter Choke - by Radioroslyn - 03-18-2021, 07:12 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-19-2021, 06:44 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-19-2021, 06:49 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-19-2021, 07:13 PM
RE: Philco 43 - Filter Choke - by Radioroslyn - 03-19-2021, 10:24 PM
RE: Philco 43 - Filter Choke - by morzh - 03-19-2021, 11:06 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-20-2021, 08:34 PM
RE: Philco 43 - Filter Choke - by morzh - 03-20-2021, 09:37 PM
RE: Philco 43 - Filter Choke - by Masonparker - 03-21-2021, 09:42 AM
RE: Philco 43 - Filter Choke - by morzh - 03-21-2021, 12:05 PM
RE: Philco 43 - Filter Choke - by Masonparker - 04-10-2021, 10:47 AM
RE: Philco 43 - Filter Choke - by Radioroslyn - 04-10-2021, 01:56 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
