Philco 84-B Early Model
I took a chance at the local Antique Shop and purchased a Philco 84-B Cathedral.
It's rather a cute style in a smaller radio. The wood is in pretty good condition. It is missing the Tuning Knob but everything else seems to be there. So far I have just set it on the shelf to admire for a while until it gets it's turn for a restore. I have about 5 old radios sitting in line ahead of this one.
[Image: https://sites.google.com/a/tds.net/white..._small.JPG]
G.
Philco 84-B Early Model - by philconerd - 03-28-2011, 12:00 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 02:21 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 03:42 PM
RE: Philco 84-B Early Model - by Jayce - 04-05-2013, 05:35 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 06:53 PM
RE: Philco 84-B Early Model - by Ron Ramirez - 04-05-2013, 08:12 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 10:59 PM
RE: Philco 84-B Early Model - by Jayce - 04-06-2013, 04:39 PM
RE: Philco 84-B Early Model - by philconerd - 04-07-2013, 07:10 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-08-2013, 08:45 PM
RE: Philco 84-B Early Model - by philconerd - 04-10-2013, 03:30 PM
RE: Philco 84-B Early Model - by philconerd - 04-11-2013, 01:30 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-12-2013, 05:54 PM
Re: Philco 34-B Early Model - by 7estatdef - 03-28-2011, 03:01 PM
Re: Philco 84-B Early Model - by philconerd - 03-28-2011, 05:41 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-28-2011, 06:27 PM
Re: Philco 84-B Early Model - by TA Forbes - 03-28-2011, 09:35 PM
Re: Philco 84-B Early Model - by philconerd - 03-29-2011, 01:10 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-29-2011, 06:11 PM
Re: Philco 84-B Early Model - by Jim Berg - 04-13-2011, 11:40 PM
Re: Philco 84-B Early Model - by retroradios - 04-17-2011, 07:07 PM
Re: Philco 84-B Early Model - by 7estatdef - 04-18-2011, 09:00 PM
Philco 91 Tuning Condenser
