GE model GD-60
I found one of those in an antique store several years ago. It had sat in water at some time. I refinished the cabinet, replaced decals on both knobs, and worked on the chassis. Just played it a few days ago...sounds good. One of my "keepers."
GE model GD-60 - by Jayce - 08-03-2010, 02:34 PM
Re: GE model GD-60 - by philcoradio1234 - 11-07-2010, 08:16 PM
Re: GE model GD-60 - by Art Hoch - 03-28-2011, 04:46 PM
Re: GE model GD-60 - by Jayce - 03-28-2011, 04:49 PM
Re: GE model GD-60 - by 7estatdef - 03-28-2011, 08:22 PM
Philco 91 Tuning Condenser
There are currently 10074 online users. [Complete List]
» 1 Member(s) | 10073 Guest(s)
