Philco 47-1230 restoration
Mine too is a 47-1230. Code 121. We can recognize the rest of the radio being the same, but the block isn't there. It is just plain confusing, to say the least.
Maybe they had changes made somewhere in the production?
How do we differenciate a mica cap from a paper cap?
-Mars
Philco 47-1230 restoration - by robertwsimpson - 02-11-2011, 09:09 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-11-2011, 02:14 PM
Re: Philco 47-1230 restoration - by TA Forbes - 02-11-2011, 02:37 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-11-2011, 11:11 PM
Re: Philco 47-1230 restoration - by marcapra - 02-12-2011, 12:16 AM
Re: Philco 47-1230 restoration - by Jayce - 02-12-2011, 02:05 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-12-2011, 09:31 PM
Re: Philco 47-1230 restoration - by DeckApe - 02-14-2011, 11:04 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-15-2011, 09:08 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-18-2011, 06:01 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-21-2011, 01:37 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 01:37 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:27 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:34 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 11:32 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 11:58 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-23-2011, 10:32 AM
Re: Philco 47-1230 restoration - by ipwizard - 04-28-2011, 06:08 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 09:54 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-29-2011, 04:07 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 05:58 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-30-2011, 01:22 AM
Re: Philco 47-1230 restoration - by Marsupial - 04-30-2011, 11:45 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 12:03 AM
Re: Philco 47-1230 restoration - by Marsupial - 05-01-2011, 12:48 AM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-01-2011, 07:54 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 10:55 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-05-2011, 09:04 AM
Philco 91 Tuning Condenser
