Interesting Model 16X Variant
I think Doug has hit the nail on the head here.
Makes sense...the ad is from March 1934, which would seem to indicate that the 16X in this cabinet probably appeared in January '34.
Interesting Model 16X Variant - by PTurney - 10-04-2005, 10:44 PM
[No subject] - by Ron Ramirez - 10-07-2005, 11:17 PM
[No subject] - by PTurney - 10-09-2005, 08:15 PM
Strange Philco 16X - by Doug Houston - 11-08-2005, 04:03 PM
[No subject] - by PTurney - 01-14-2006, 09:15 PM
Update. - by PTurney - 03-24-2006, 07:03 PM
[No subject] - by PTurney - 03-26-2006, 01:08 PM
[No subject] - by Doug Houston - 03-27-2006, 12:45 AM
[No subject] - by Ron Ramirez - 03-27-2006, 10:48 PM
[No subject] - by PTurney - 03-28-2006, 12:31 AM
[No subject] - by Ron Ramirez - 03-28-2006, 09:28 PM
There are currently 10100 online users. [Complete List]
» 1 Member(s) | 10099 Guest(s)
